What project thread!
So in theory I could fit a near 5m car in but I'd not be able to get in there to work on it so kind of pointless.
I think anything much less than a metre gap is gonna become annoying fast. RX7 FC = 4.3m long. MGBGT = 4.1 for the longer rubber bumper model. I suppose I could put a Duratec V6 in with a jag ZF gearbox. But an MGBGT still doesn't grab me as something worth spending time and money on...
Renrut wrote: But an MGBGT still doesn't grab me as something worth spending time and money on...
I'm with you on that Will.
I'd have another FC in a flash, as long as it was solid. When you work on them and see little bits like alloy front wishbones, nice 4-pot calipers etc, then drive them round the Ring and see what they're capable of you realise how good they are.
TeamTotalWankel - Posts: 2355
Getting another cento (cinq or sei) does make sense, they're dirt cheap with a broken engine, I've already got lots of spare parts (gearbox, diff, wishbones, shocks big brakes, etc etc) and it does fit in the garage easily. Keep it front engine fwd and see what can be squeezed in there. I could even use the shell I've got as a test bed to see what will fit
Biggest anyone has managed to my knowledge was a 150bhp redtop with a bit of cutting about of chassis legs and putting the radiators in the back. But what would I put in it? (some one is gonna say 13B aren't they)
http://www.ebay.co.uk/itm/Daihatsu-Char ... 231675e322
http://www.ebay.co.uk/itm/NISSAN-SILVIA ... 45fe92b068
http://www.ebay.co.uk/itm/1993-NISSAN-S ... 19cac4b558
S12 the thinking mans 12A?
Relentless Rob - Posts: 5153
Sell me the VTR lump and buy the SAAB and a roll of duct-tape.
Don't think a Saab lump would fit in the front unless its smaller than a redtop. The redtop one had to have quite a bit of inner wing cutting and iirc the wheels hit the gearbox on full lock.
What's the thoughts on welding back up the rear end and putting [insert interesting engine here] in the front? I'd have to check that I haven't hacked off any of the rear axle mounting points but I don't think I did.
Steve33 wrote:Thats an idea would a 20vt from a coupe fit?
You already have the basics but how would that affect the 999 budget ?
The 20VT barely fits the Fiat Coupe' let alone the Seicento.
The idea of swapping the 20V N/A from a Bravo 155 HGT with the 20VT is straight forward and could potentially be awesome. A few Johnys have done the conversion and the little difference in weight between the Bravo and Coupe' engines mean the chassis dynamic is largley uneffected. The 16V turbo will fit in the engine bay of a Punto HGT snuggly as well.
As Rob says the 20VT are quite wide/long but would be a potential to fit in the back but bear in mind that the back of a seicento is actually about 100mm narrower than the front you only save on the wheels not having to turn.
I've had a nose at the mess in the garage. The mounting points are still present to bolt a fiat subframe back on if I wanted to put it back to a normal fiat rear subframe.
I'll measure the engine bay up if anyone knows of something that might fit but approximately its:
700mm between the upper chassis legs.
700mm from lowest point the front suspension mounting brackets.
600mm from bulkhead to front crossmember but that has to include the driveshafts at about 100mm from the bulkhead.
Users browsing this forum: Google [Bot] and 3 guests
