Engine out of the MR2, started to strip it down
Well, took the engine out of the MR2 yesterday and spent most of this evening stripping it down.
Here are a few pics of my ordeal. Forgive the quality, theyre all off the phone.
First couple of hoses off
All pipework off from the top, ready for dismantling crossmember & suspension underneath
A shot of the inlet with the injectors exposed, and some of my labelling
Another shot of my masking tape labelling system
Got her up on the lift then to remove this beasty (Yes I know the shafts are off in this pic, it was the only one I had of the crossmember still in the car)
Tie bars then came off meaning I could swing the hubs out
And then pull the driveshafts out
Disconnect the droplinks, and get the bugger out
We then raised the car away from the engine on the lift, and I was extremely glad to be left with this when the lift went up
The pile of parts mounting in the corner
Have a look at this for a hosing nightmare - This is going to be a nasty one to replum!!
This is the last time this turbo will be on the engine
Head off
And the block
After all that I'm well knackered, and there is at least as much work to go! I have all the bolts out of the gearbox and will split it from the block tomorrow. Have a 6 plate clutch to go in there to take the new horspepower and torque!
- mark239
Well, got the sump off:
Extracted Number one piston and saw the damage after I wiped the oil off it.
I tapped the back of the piston and the bits broke off!!
Thank god I didnt drive it hard or far with the piston in that shape or I would have been looking for a new block as well !!
- mark239
JE Forged pistons (86.5mm 9:1 CR)
HKS Stopper type 1.6mm Head gasket
ARP head kit
ARP big end kit
Clevite mains, thrust washers, big end bearings
GT35 compatible downpipe
T3 adapter flange with 38mm wastegate port
Tial 38mm external wastegate
Complete gasket set
oil pump
water pump
timing belt
To order this week:
Garrett GT3582r turbo (Yeah!!!)
puck clutch (6 plate)
Next month, on Payday
Link G3 ECU & Harness adapter
Delphi 870cc injectors
There is gonna be some kick off this little MR2
Total cost has been offset well with the sale of a lot of the original parts and my beloved cisco 3560 power over ethernet switch.
- mark239
Return to Events : What are you doing at weekends?
