Hypermiling - Anyone tried it?
owelly wrote:I bought a car with an 'econogauge' once.
Was it a Volvo 360? Mines got one!
DavidVizard wrote:The higher you can keep the vacuum the better your mileage should be
Except the Swedes make me keep the needle down.
Does that mean its showing vacuum on a reverse scale or reading boost?
It does seem to work though. I've tried copying the 'successful' techniques on my other car but they're hard to replicate on a Land Rover 90
- brickie501
DV
- DavidVizard
It does seem to respond well to the pulsing and then letting the speed fall gradually (say 60-50 over a few minutes), I'm guessing this is because its no longer stressing the drivetrain as much while its slowing so friction is minimised. This is what they do for those solar challenge cars and works well for them. Obviously this isn't good for traffic so I only do it when the roads are clear.
I think I need a target - 40mpg on mostly motorway driving seems like a good one, realistic but still a stretch. I'll go motorway route home tonight. I've found that the cars mpg gauge is reasonably accurate so if I get good results on that I'll try a proper one with a tank to tank measurement.
Renrut - Posts: 4577
mjslonergan - Posts: 1363
And yes it is getting a bit anal
A6 2.5 TDI (5cyl 140 horse). I find that pumping the tyres up to the "laden" settings and driving a bit slower (ie staying legal) has a decent effect. Slowing down a bit more (65 ish) helps a bit more but less than that means it drops off boost in 6th so is actually a bit worse. Treating it nicely, as above won me an average of 56 mpg over a 1400 mile holiday trip from Somerset to Scottish highlands with some driving round the highlands thrown in. But for the highlands part would probably have cracked 60 mpg. Which is pretty damn good for a 1.6 tonne barge with a 2.5L engine and 240k on the clock I thought. Better than my colleagues new Bluemotion Passat in the real world anyway!
Another example - '67 Vitesse 2L mk 2. Has electronic engine management courtesy of Megasquirt, but the engine itself is pretty much standard internally. "Spirited" driving around Europe on a club event, including a fair bit of Alpine pass action netted an average of 35 mpg over 2600 miles. Worst tank - 21 mpg - yes, there were multiple Alps involved in that one, taken in attacking style, best tank 39 mpg on Austrian motorways (lots of traffic cops and tunnels with low speed limits). A similar trip with the family (yes, driving much slower but still keeping up with the traffic) gave 39 mpg over 1600 miles, worst tank 29 mpg (Alps involved but driven more sedately), best tank 43 mpg on French motorways in no hurry. Surprisingly little difference overall I thought.....
Nick
- VitesseEFI
I've managed to get my commute up to about 29mpg from 22mpg but its now getting depressingly dull, this is effectively driving the car everywhere below 2000rpm and letting the torque pull me up to speed which it manages without struggling but it is so boring. I'm due to refill the tank this week, I'll see what I've achieved real world and that will conclude this thought experiment. Bottom line is I'll go back to enjoying having 240bhp under my right foot, if I wanted to drive like Morgan Freeman I'd have bought a bloody 1.0 NA diesel!
In other news I finally got round to fitting the filler cap for my LPG
owelly - Posts: 6411
The experiment has gone out the window now, over the tank I managed 28mpg. Which is unsurprisingly around what Jaguar quote as the 'combined consumption' as it was mixed motorway and town commuting.
I did get better than their extra urban figure of 34 though. I'm back to driving normally as it means I enjoy the car rather than feel like I'm sitting a driving test every time I get into it.
I found that dropping to a narrower tyre and stretching them slightly to fit the rim and keeping the tyres pumped up to 36psi, never going over 60mph and free wheeling down every incline and approx 100yards before going up a hill slightly put the power back on I was achieving around 80mpg on a regular basis, I never revved the car over 2100rmp, all excess weight was removed, and if you look ahead as far as you can (to the next bend) then you are more prepared for what is coming,you can still see the car in front of you and you automatically position yourself better on the road......
- gary5687
gary5687 wrote:I found that dropping to a narrower tyre and stretching them slightly to fit the rim and keeping the tyres pumped up to 36psi,
woah 36psi in a yaris? The jag was a handful with 36psi and that weighs probably twice a yaris. Wasn't it a bit slippery with them that high?
Renrut wrote:gary5687 wrote:I found that dropping to a narrower tyre and stretching them slightly to fit the rim and keeping the tyres pumped up to 36psi,
In fairness being a Yaris, tyre pressures are hardly going to make a difference to its 'handling'...
Users browsing this forum: Google [Bot] and 2 guests
