Help, I need some new door handles!!
Can anyone here help me?
I'm trying to find a pair of new interior door catches/handles for my Reliant Ant project.
Does anyone here know where I might get some?
Here's a couple of pictures...
Cheers Frank.
fha772 - Posts: 4955
owelly - Posts: 6411
mjslonergan - Posts: 1363
Can you upgrade to something more modern? Bear claw or after market kit car stuff?
I know someone who has a "Lambo" door kit for a Saxo project if you like.
Relentless Rob - Posts: 5187
Relentless Rob wrote:Can you upgrade to something more modern? Bear claw or after market kit car stuff?
Not really, the doors are bearly over an inch thick, there's just no room to alter them.
I'm going to have a go at stripping and rebuilding these catches, but I think they're too far gone.
http://item.mobileweb.ebay.co.uk/viewit ... 0765615024
I know I've seen them on tractors/diggers/plant, it just bugging me where I've seen them...
The exterior handles are easy, they're off a Morris 8.
74 series, 84 series, 85 series & 95 series tractors fitted with Victor or L type cabs.
http://www.vapormatic.co.uk/tractor-par ... st/VLD1404
Part number: VLD1403
They are what the farm places had, they are about 1/2 inch wider, and the latch part(bit that sticks out and holds the door in), is offset. It needs to be inline with the handle.
It's nearly the same faults as the Landy 1, basicly, if the square hole is through the back plate, it's wrong.
But after getting them off, I think I can rebuild them...
Hopefully!!
