It is currently Wed May 22, 2013 12:00 am
What to do with an old estate car
Postby Robmarriott » Thu Aug 09, 2012 8:49 am
B
T
C
C
That is all
Robmarriott
Postby Renrut » Thu Aug 09, 2012 4:36 pm
:D
I do have an old copy of CCC which covers the early 2000 BTCC primera and the modifications it went through. 306bhp NA and a 8000rpm rev limit :crazy:
Used the pulsar block but reversed the head to allow a ram air effect from the massive CF intake (basically the front of the car as a ramscoop) and move the block further back in the chassis. Was awesome.
I'll be up at the old folks home this weekend, I'll take some pictures and see if its worth saving or just dragging to the scrap man.
Postby Renrut » Tue Aug 14, 2012 8:43 am
Was at the old folks home at the weekend so took some photos of it sitting there all forlorn.
My dad showed me the MOT failure sheet. 2 rust failures, underneath is rotting out too near the suspension. Other than that, a dubious wheel bearing and a CV gaiter. Emissions test was fine.
Got him to start the engine up, made a bit of a clattery noise on starting but once running it sounded normal. I suspect thats because it has been sitting and the oil has drained away from things. It has 130,000 miles on it NOT 170 as my mum said on the phone.
Other bits - passenger side window spontaneously exploded the other day in the heat, suspected delamination of the glass.
Front drivers tyre is not holding air, hence the jack in the photo :lol:
Looks to me like a parts car, engine good but body is long past best, rescuable if you're bothered but primeras this age are common in far better condition. If anyone fancies it drop me a PM and I'll pass on the contact details.
Postby ACE » Wed Aug 22, 2012 9:28 pm
1, put a V8 in it.
2, put a V12 in it.
3, put a V8 and a V12 in it.
Or
4, slice out the entire floor pan, engine, etc.
Weld in a shortened (by 214mm) Lexus LS400.
Go Audi bating (Merlin powered coach bating?)
ACE
Postby Renrut » Thu Aug 23, 2012 3:25 pm
The ironic thing is the engine is the best bit of it! :lol:
To take advantage of that - bolt on GT25 turbo using GTI-R manifold and some ghetto fueling mods. Chop out as much of the interior of the car and shave as much weight off as possible in a similar vein to that crazy proton in the 2nd 999 challenge - go mad with a hole saw and polycarb sheets.
Postby Relentless Rob » Tue Sep 04, 2012 7:23 pm
Put the engine and gearbox in a £200 Micra? :think:
Then annoy a Subaru driver. ;)
http://www.ebay.co.uk/itm/Nissan-Micra- ... 706wt_1373
Postby Renrut » Tue Sep 04, 2012 8:50 pm
But a pulsar engine is a few tweaks from 400bhp, a primera one is a bit further off that. It would scare some less serious kit though like TDI audis and stuff like that. And still get 40+mpg :D
Postby Relentless Rob » Wed Sep 05, 2012 3:40 am
It's an Almera GTI engine according to the blurb. The guy said it was a Pulsar and got ripped for it. ;)
Postby DaveRoverMan » Wed Sep 05, 2012 7:57 am
Gotta love keyboard experts commenting on YouTube videos?
DaveRoverMan
Postby Renrut » Wed Sep 05, 2012 10:50 pm
DaveRoverMan wrote:Gotta love keyboard experts commenting on YouTube videos?
Postby mjslonergan » Wed Sep 05, 2012 10:55 pm
Love it :lol:
Postby Relentless Rob » Fri Oct 05, 2012 9:00 am
Bigger engine bay...
http://www.ebay.co.uk/itm/NISSAN-MICRA- ... 297wt_1373
...I'd wear a pensioner disguise (like a Beastie Boys video) and go Saxo baiting. ;)
Previous
