Hmmmm, Can i enter a lorry in the £999...
This one really needs a build diary!!!!
- havinalaff
Weld the two rear wheels together and use a pair of 800 section tyres from an Ant?
Could be on to something here.
I know I said "some turbo diesels" could be competetive but Practical Performance Truck?
Relentless Rob - Posts: 5153
(I mean, in theory of course, i would never drive that fast on public roads, even in a car).
This lorry is a 1979, so it pre-dates any speed limiter laws.
Silkolene, used to race the same model unit, in the 80's, all they had done to that was turn up the boost and fit a race seat, harness, and rollcage. Monday to friday in was used for haulage. They used to hit over 100mph on the track.
fha772 - Posts: 4946
I like ERF's. Especially the noise a cummins 6 makes when its on cam. They sing.
- havinalaff
A) you'd strip everything you can(like with a car), this would include, the whole cab interior, replace side/rear windows with perspex, take off the 5th wheel coupling, remove the inner wheels on the rear, take off the twin diesel tanks and replace with a single small tank, etc...
This should remove somewhere in the region of 1-1.5 ton.
B) using Cummins data sheets, adjust the injector pump for maximum power/torque, this involves only time, not parts.
C) using either shims/washers or replace the spring, alter the wastegate actuator to increase the turbo boost pressure.
D) weld up the reduction hub gears to increase the final drive to 1:1 rather than 3:1.
E) run it in for a special vehicles test(pretty close to a car MOT), as it is no longer a haulage lorry.
F) win the £999!!!!
That is pretty much it, apart from some odd minor jobs.
You're looking at about £200 for the jobs and about £500-700 for the lorry.
I'm thinking outside the box for the £999 as well.
There will be a fair bit of chassis that will be surplus to requirements too, if you have the angle grinder out anyway.
Relentless Rob wrote:I'm thinking outside the box for the £999 as well...
I didn't even know there was a box!!!!
OilyFingers, It's a 14 litre "Big Cam" Cummins
(it may even get twin, 10 litre Cummins turbos)
LOL
Rich
p.s. i wasn't coming to 999 challenge but if this happens I would!!!!
- havinalaff
The ERF would be just a bit of sillyness, and i don't think i'll have time to do anything other than buy it this year.
But we'll see...
But, his father-in-law is swapping lorries soon, and he has a 265 Rolls Royce Eagle powered 4 wheel ERF.
The Rolls Eagle engine is easier to tune, because it's a linear pump, so it's easier, and less complicated to alter.
