Oddball trackday car
- Steve33
Assuming the Mobs will move it, there are plenty of weird things using the 200sx drivetrain and even floorpan knocking around, a quick youtube/google will show them up.
Probably needs a bit more formed thought though, spend a bit longer in the bath and have a good 'ol soak.
Renrut - Posts: 4560
What about taking the headstock off a bike and mounting the remainder to the front of a car so the third pin is at the back not the front and you don't have to faff about with reverse gears or mounting drive converters etc because its a trike not a car.
Its not an original idea but has to be simple enough.
OilyFingers wrote:What about taking the headstock off a bike and mounting the remainder to the front of a car so the third pin is at the back not the front and you don't have to faff about with reverse gears or mounting drive converters etc because its a trike not a car.
A single seater with the driver sat knee level with the front wheels perhaps?
Or how about a Locost front with the back of a bike (or two)?
Whatever you do a lot of bike powered kit car boys forget to take the extra weight into account. In some cases it's a simple extra couple of friction plates to make the clutch man enough for the task but it can be a total rebuild of the bottom half of the engine if you get your sums wrong. A replacement engine will repeat the same self destruction because you're only dealing with the effects rather than the cause. Also the DVLA take a dim view of these (not that a track day car needs to be on the road) two wheels at the front being powered by one rear for some reason does not qualify as a bike derived trike because it has more characteristic of a car.
Steves idea of using a transaxle gear box with some J-power? I'd start with an old race car chassis and find a turbo or N/A four pot already on a transaxle. SAAB/VAG turbo or N/A maybe? Then it's fairly straight forward gearbox, engine mounts, carriers and gear linkage fabrication. You can modify the original hubs and driveshafts to suit.
Something like this could work...
http://www.ebay.co.uk/itm/Mondiale-M84- ... 41612c2d85
...gratuitous eBay link.
Much better solution would be to graft the back of a bike onto a shortened haynes roadster front end. Don't bother with a diff at the back just have a solid shaft and a single brake on the rear all hanging off the bikes original swing arm. Might need a beefier rear spring and shock, and perhaps to pick an older bike with a steel frame thats easier to weld to than the fancy fabricated ally things you see now.
Mind you they were outlawed for being dangerous so now it would be worse.
999 challenge anyone ?
- Steve33
How about a Peel P50 modified, it has 2 front wheels and a single
rear wheel. Or a Bubble car as they have 2 front wheels and a rear
wheel. Both these cars are more stable than the bond bug 3 wheeler.
So instead of going large, how small can you go?
mitsuru - Posts: 1183
Not sure the stewards would like it though.
Steve33 wrote:Anyone seen a nova vw based kit car ?
I iad an idea for an impreza powered example but the entire running gear transplanted so it handles and stops as well.
I've seen one with an Alfa flat 4... Subaru turbo sounds better.
- MFrV1
http://www.ebay.co.uk/itm/Race-car-hill ... 27c2a8ed6a
...all you need now is some duct-tape a bike and a seat.
The Nova car always reminded me of the Pink Panther mobile from the start of the cartoons. I wouldn't write off the VW engine either. I remember a Nova in the Outlaw Warrior Four steries with a bonkers aircooled lump powering it. On a more realistic budget and if there's one thing the anti-dub scene has shown us; it's the number of potential donors for Beetle platform is vast. With Beetle parts becoming more and more (ridiculously) expensive kit car builders like Covin are turning to other mid/rear engined cars for their porsche 911 replicas. MGF', MR2's and so on. You could always take a grinder to the Nova and fit MR2 Turbo running gear in there.
Users browsing this forum: Rippthrough and 1 guest
