It is currently Sat May 18, 2013 4:27 pm
Freelander TD4 power upgrade
Postby DaveRoverMan » Tue Apr 17, 2012 9:32 pm
Popular opinion is the Td5 shares it's bore/stroke and even rod design with the O Series, and I turn with the Prima, M Series, T Series, and L Series engines which all share the same/similar blocks.
I've never had a piston/rod from more than one in my hand at any one time, so can't confirm it any further.
DaveRoverMan
Postby Chairchild » Sun Apr 22, 2012 8:27 pm
brickie501 wrote:
Chairchild wrote: swap the injector nozzles to Freelander 300TDi items, to get yourself well over 200Bhp, and in excess of 350lb/ft of torque....
I take it you mean Defender / Discovery 300Tdi injectors? (Tdi was never fitted to Freelanders ... at least not by factory :think:)
Didn't realise they (the injectors - not a Tdi; that would be a challenge :lol:) would fit.
Hmmmm :think:
To continue the 'parts bin enineering theme', can anyone confirm if L Series & Land Rover Td5 pistons are the same?
Freelander, discovery, same thing :? lol
It's not the whole injectors - they're too long, and the high pressure lines wouldn't fit. Just the nozzles from the injectors ;) Once mine passes about 150Bhp, it's a mod I'll be doing
Chairchild
Postby brickie501 » Mon Apr 23, 2012 11:46 pm
The nozzle bit is obvious now I've stopped being a numpty & re-read your post :oops:
Interesting that you can uprate injectors like that & could turn out to be useful; thanks
brickie501
Previous
