Capri 1.6LS
I’ve not reported on the Capri for a while but progress has not slowed, here’s the latest update:
All of the front suspension components were removed and sent for shot blasting by a firm in Corby. I then cut the spring seats off the front struts after removing the old shock absorber assemblies ready for conversion to coil over spec along with gas shock inserts. All of the shot blasted metalwork is now primed and will be painted with some left over red 2 pack I have lying around – very fetching.
I’ve not been so lucky with the body though… I knew the strut tops were an MOT fail so I cut out all of the rust which then required the removal of the passenger wing. That’s when it all went wrong.
Behind the wing, next to the A pillar was a block of expanding foam which was holding various structural components together and explains why the passenger door was dropping when opened! I reckon I can fashion some sizable repair panels from scrap steel sheet so it won’t be an expensive repair, but it will take lots of precious time.
I’ll get stuck into that over the next few weekends but my deadline of PPC in the Park is looking a bit shaky
Max - Posts: 239
Max wrote:Right, time to get back on topic![]()
That's what happens when you leave threads unattended.
Max wrote: I’ll get stuck into that over the next few weekends but my deadline of PPC in the Park is looking a bit shaky
Enter try not to be too shaky and do a Will' line here.
That's the problem with old cars you get old bodges with them. Still a good oportunity to seem weld the body together for extra strengh and possibly run some box from the bulkhead to the strut tops to reduce torque twist. I have some leaf lowering blocks somewhere if you'd like to drop the back in line with the front unless you're planning a D.I.Y four link set up as well.
Relentless Rob - Posts: 5182
Given the abundance of rust I'm sure the rear spring mounts will need attention soon though. I'm toying with the idea of Sierra IRS but haven't looked into the width yet. I really want to keep the 13" RS 4 spokes (the later fake ones - I know purists) so it'll probably mean keeping drum brakes. The alternative is a Porsche 924 IRS set up with a diff off a BM or Merc so I keep the 108mm PCD but that seems like a very complicated idea
Max - Posts: 239
You can use any diff' so long as you have 4x108 hubs.
No pressure but I have just passed on a link to this thread to a chap in the Capri owners club.
The welding was on the A post where the bulk head meets. He has managed to convert the front struts to coilovers with KYB gas inserts and gussets, these are now nice, shiny and red, not the boring usual blue...! Sorry I can't give you more description but Max is washing up and don't want to disturb him!!!! I will tell him about this post once he has finished the hoovering.
Interested in your club attending? Just get in touch and we'll make sure you have an awesome day.
- Kate Miller
owelly - Posts: 6411
...Practical Performance Kirby?
It would be a straight forward fit to your car and an interesting interview for the mag if you're not too busy cleaning one weekend.
http://editions.pagesuite.co.uk/_psedit ... Page80.pdf
Very nice chap.
I have now got to the stage that I can open the door without it dropping so it's not all bad and the hole that was allowing the neighbour's cat to get into the car and sleep is now solid metal again - sorry Henry you'll have to find a new home
Next step is to turn the inner wheel arches I cut out of a VW Caddy into a headlamp bowl, profiles are pretty much spot on...
Max - Posts: 239
Have you borrowed the clock from PPC towers?
