It is currently Mon May 20, 2013 8:32 am
saabinator 2
Postby froggy » Fri Jan 14, 2011 6:51 pm
couple of bottles of K seal should sort this out
froggy
Postby TeamTotalWankel » Fri Jan 14, 2011 7:10 pm
Holy split block Batman!! :shock:
Postby bulletproofbob » Fri Jan 14, 2011 8:26 pm
lillets maybe? they normally stop the warm fluids leaking from the cracks of...... oh hang on, wrong forum :oops:
Postby McVities » Sat Jan 15, 2011 12:27 am
I'm sure there's a follow-on joke here somewhere about it being front-bottomed :lol: :lol:
McVities
Postby bulletproofbob » Sat Jan 15, 2011 9:15 am
McVities wrote:I'm sure there's a follow-on joke here somewhere about it being front-bottomed :lol: :lol:
rolf!!
if i can get pic off my phone i'll show you a real crack!!! its not what your thinking ttw, its from work when good pipe goes pop!!!!
Postby Smiler » Sun Jan 16, 2011 1:27 am
Wow, this thread is really making me feel a bit amature in my technical know-how! Sorry to see the blow up but that's half the fun I suppose.
Smiler
Postby bulletproofbob » Sun Jan 16, 2011 9:28 am
Smiler wrote:Wow, this thread is really making me feel a bit amature in my technical know-how! Sorry to see the blow up but that's half the fun I suppose.
only half the fun if its not yours :wink:
Postby froggy » Sun Jan 16, 2011 11:39 am
as its no 1 cylinder that went bad i need to re think how im measuring boost and rather than reading boost from just behind the throttle body it needs to come off the manifold runner on no 1 cylinder as thats obviously seeing more pressure than the others under full chat .
the 3 bar map sensor cant see pressure above 2 bar so seeing 2.5 bar on my gauge at the throttle body could be closer to 3 bar at no1 cylinder so no wonder it burst :(
froggy
Postby McVities » Sun Jan 16, 2011 2:23 pm
are you still using the standard 9000 inlet manifold?
It's a poor design, and uses an internal blanking plate on (yup you guessed it) cylinder 1 to try and equalise air delivery to all the cylinders.
It works ok at standard levels but you may have found it's limits......
Edit - I think someone on UKSaabs found a supply of cheap-ish 4-bar MAP sensors a short while back
McVities
Postby froggy » Sun Jan 16, 2011 5:34 pm
i logged 580hp at 5000rpm when it blew and the log showed the map off the scale at 4200 so it could have reached 3 bar .
given what the vgt can flow i think 500hp will be well under 2 bar and il happily trade top end power for better spool .
luckily for me uk saabs has plenty of support for new ideas and im getting help with developement from the guys over there
froggy
Postby froggy » Sat Apr 02, 2011 7:13 pm
SHE LIVES !!!!!
the poor thing has been stuck at the back of the shop since christmas and in typical saab style the engine that had sat on the floor for 18months started on the button :)
the 2.3 has definitely improved off boost driving and helped it get to 0.5 bar with better torque rise . the boost is capped at 1 bar for now and ive put a gauge in the car to measure backpressure at the manifold although i have no idea what the reading means i should be able to see how vane position affects backpressure
froggy
Postby bulletproofbob » Sat Apr 02, 2011 8:25 pm
you just need a "back off god on board" sticker and you have the greatest of sleepers!!! i love this beastie :clap:
Postby froggy » Sat Apr 02, 2011 8:38 pm
froggy
Postby owelly » Sat Apr 02, 2011 9:04 pm
Nah. This little piggy went pop.....
Postby bulletproofbob » Sun Apr 03, 2011 7:46 am
froggy wrote:Image
lmao!!!!
Return to £999 2011 Builds
