It is currently Thu May 23, 2013 6:57 pm
Postby TeamTotalWankel » Fri Nov 05, 2010 2:16 pm
That's not bad mate :clap:
Would make a good conversion into the back of something, like a small hatchback. What's the BHP as std?
Postby owelly » Fri Nov 05, 2010 2:38 pm
Ah! Now there's the thing.......
I wanted the VVC 210bhp unit but to use the standard ECU, you need the entire 'multiplex' can-bus loom with everything from the dash set to the key transponders. If you miss any bits out, the ECU goes in to sulky mode.
I ended up with the 194bhp engine which has proper blokes wires. With a de-cat, freeflow chimney and panel filter, standard 406 Coupes poke out 212-220bhp. The ECU can be remapped or there is a Clio V6 ECU which will wind the power up if I can find which one it is. It's the same one the Frog Plod use in their 406 Plod cars.....
Postby TeamTotalWankel » Fri Nov 05, 2010 2:59 pm
owelly wrote:Ah! Now there's the thing.......
220bhp, nice. Should be more than enough to mangle your Twiglet derived drivetrain. :wink:
Postby Jaffa » Fri Nov 05, 2010 5:03 pm
owelly wrote: And for those of you with keen eyes and an interest in XR4x4s, will recognise the struts and uprights....
spot the plan?
Postby TeamTotalWankel » Fri Nov 05, 2010 5:49 pm
spot the plan?
3.0 V6 24v 4wd pile of sh1te? :think: :clap: :lol:
Postby Jaffa » Fri Nov 05, 2010 9:08 pm
Thats a good point, well made :shock:
Postby Relentless Rob » Fri Nov 05, 2010 11:20 pm
:think:
So TW, Daz', and Owelly are opting for V6's. Interesting.
Postby TeamTotalWankel » Sat Nov 06, 2010 9:03 am
Relentless Rob wrote::think:
And all with different layouts- FWD, mid eng RWD, front eng 4wd :clap:
Postby Jaffa » Sat Nov 06, 2010 9:22 am
or in Oweelys case, no wheel drive
Postby Relentless Rob » Sat Nov 06, 2010 3:14 pm
Having a haggle with the ideal candidate for my project. May opt' for a front mounted rear wheel drive V6 due to the space/performance ratio. ;)
Postby owelly » Mon Nov 08, 2010 9:27 pm
So, after a few nightshifts, a swarf pile as big as a big bear, a few swarf burns, a few swarf cuts and a totally ruined fleec, cause by being melted by swarf, I have......<<drum roll>>
V6 gearbox.
V6 gearbox pulled to bits to get the bellhousing end.
Making swarf.
More swarf.
Offset swarf making.
Bibbles to transfer the holes to a template.
And the 'finished'adaptor plate. Just needs ffive more holes once I have the gearbox levelled to the engine.
Postby Jaffa » Mon Nov 08, 2010 10:16 pm
I don't understand!!!!!
draw me a picture :crazy:
Postby owelly » Mon Nov 08, 2010 10:34 pm
Apologies for the immensely childish drawing but you should get the idea...Image
Postby Relentless Rob » Tue Nov 09, 2010 10:56 am
:clap: :clap: :clap: :clap: :clap:
Postby tommi » Tue Nov 09, 2010 12:27 pm
i have to say that is some excelent work.
