Shall I bring my spare sierra LSD and shafts or save them for Santa Pod?
TeamTotalWankel - Posts: 2355
I wasted an hour today looking for the battery for the Turd. No sign of it anywhere. Having remembered what the big battery was that I kept tripping over, it was off the A4, I recalled fitting the Turd battery in its place. Quick trip to Halfords to replace Audi battery so I can reclaim Turd battery......
owelly wrote:If it doesn't work, expect to see a Bongo out on the track!
You can race that bird in the white Trannie if she turns up again
owelly wrote:Oh, yeah! I have AWD and an LSD.....and knobbly remoulds.
Off-road course it is then
I read that completely wrong... while thinking about lady tansit drivers...owelly wrote:knobbly remoulds.
Trailer dangling off the back of the Bongo. Plastic car sat on the trailer. If I had gone for a blat up the road, which I didn't, then I certainly didn't set off dozens of car alarms. Baaarrrrp!
Shakedown at Mallory went well once the track dried. I was beginning to think I'd totally screwed-up the rear axle gubbins as the car was just about impossible to drive in the wet!
Once dry, the lack of working steering reared its head once more so that needs sorting.
The engine got too hot when worked hard so it needs a bigger radiator.
My araldite bodge on the diff cover gave way whilst cocking about on the campsite after the event so that needs to come off and a blob of ally clagging on.
Then it'll be good enough for the £999.
It still needs a new pedal box making to make the clutch and brakes usable but that can wait until after the new front brakes are made to fit.
The whole car needs to come to pieces so I can make the chassis square and symmetrical and to make the body fit better, but that will be near the bottom of the list.
I think the rad'll probably be OK for the £999 too as it's only short blasts, not like the sustained thrashing of a trackday.
The steering sounds like it's the BIG issue to me. I've got various steering UJs here if you need owt.
owelly wrote:I've sorted the steering. A length of garden hose and two Jubilee clips.
Why didn't anyone else think of that??
