owelly - Posts: 6411
Specially colour-coded so I know which side is where the driver sits.
It seems from initial research, that the EPAS ECU is totally different from the Corsa one and it could be a lot easier to adapt for transplant into other vehicles:
1. The Corsa ECU has to see a specific pulsed signal from the cars main ECU whilst the engine is running to enable the EPAS to wake up. This is so the EPAS doesn't slurp the battery dry cos the engine's not running. The Agila/WagonR EPAS ECU gas to see at least 1v and it will work.
2. The Corsa EPAS ECU wants to see a sine wave signal for a speed referance. On the Corsa this comes from the speedo/clocks which converts the signal from the main ECU which picks its signal from the ABS circuit or the final drive pick-up. The Agila/WagonR uses a pulsed feed direct from a speed sensor on the gearbox.
3. The Corsa column is heavy to use when there system isn't running. The Agila/WagonR has an electro-clutch to overcome this.
4. The Agila/WagonR column is shorter so easier to fit into small spaces whereas the Corsa one often has to be shortened.
5. The Agila/WagonR unit weights less than the Corsa unit.
So far, the only obvious downside for me appears to be the steering wheel fitment which is not like anything I have on my shelves. It's a big spline with a hole down the middle for a bolt rather than a threaded stub for a nut. I guess I'll be welding the end of my old column to the top of the Agila one....
Having said all of the above, I havn't got this thing anywhere near the car yet so I don't know if it will work. I do have Renruts electro-speedo drive handy so I may a stick a sprocket in the battery drill and wire up the column on the bench (top of the wheely bin) and see what occurs. Watch this space...
If Jaffa's MGF has non-assisted steering, then can I offer some beer tokens for its steering column?
Rob Bell - Posts: 357
Good luck with the bits - these cars are worth considerably more in parts than they are as a whole unfortunately - but I reckon you'll get your investment back at least
