It is currently Thu May 23, 2013 9:57 am
Postby Jaffa » Sat Jan 15, 2011 2:22 pm
its not
Postby TeamTotalWankel » Sat Jan 15, 2011 10:33 pm
That's a shame, hope it gets sorted. Wouldn't be the same without the 'TT'. :eh:
Postby owelly » Sun Jan 16, 2011 11:31 pm
HA! In your face, you doubting Thomaseseses....
I had a spare day today plus a couple of hours lastnight and the result is........
Old Alfa engine out. Gearbox off. Gearbox bolted to Pug V6 and the whole lot dropped back into the Turd. I have roughed out (they will stay!) engine mounts and will need to adjust the rear 'box mounting which means the hole in the transmission tunnel will
need 'stretching' but it's close enough. The old chimneys align with where the Pug manifolds end so they just need new flanges welding on. The Polo rad Jaffa gifted the project fits in the nose of the car and just needs a couple of holes in the lower x-member to secure. I've cut the pipes for the coolant and need to use my new patented beading tool to stop the hoses from getting off.
I've modified the area where the current pedal box fits so the air intake plenum will fit without too much fuss and I've made a new floor mounted pedal box which fits a treat but as yet, it still needs bolting down and plumbing in.
The sump on the Pug V6 is no lower than the flywheel so it needs no modifications and the oil filter is tucked out of the way so no need for the remote housing.
I've retained the entire fuel supply from the tank, through the LP lift pump, through the Golf GTi HP and swirl pot up to the filter and onto the fuel rail. I need some Pug fittings to retain the unclippy hosey bits otherwise I'll just push rubber hoses on and a worn drive clip or two.
Just the sparks to sort out and it will be a runner.
As for the chassis: I've maesured the rear end for the de-dion conversion and Auto Cad'd some dimensions. I'll get on with that at the weekend whilst at work. The front end may not get the double wishbones just yet. Just a tweak of the current wishbone upper/Escort TCA setup.
So. You pack of gibbering pillocks who would rather sit on here twisting at me for not getting on with the Turd, than get on with your own £999 projects, who's laughing now? Eh??
PS. None of the above is true. The car is still in the shed where I dumped it after the last £999. I've been to the Autosport show this weekend and to IKEA for meatballs and jam......
X
Postby TeamTotalWankel » Sun Jan 16, 2011 11:42 pm
:clap: thought so :lol:
Postby fha772 » Mon Jan 17, 2011 12:09 am
OWELLY!!! :wave: :clap:
We've missed you!!!
Postby owelly » Mon Jan 17, 2011 12:39 am
:wave: :wave: Hi darlings.... :wink:
Postby TeamTotalWankel » Mon Jan 17, 2011 7:59 am
Ok, thats enough man-hugging now chaps!! :oops:
Now pull your chubby finger out owelly and get that Pug V6 in for real :wink:
Postby DumDum » Mon Jan 17, 2011 11:27 am
You had me falling for that hook, line and sinker. It all sounded so beleivable
DumDum
Postby TeamTotalWankel » Mon Jan 17, 2011 11:42 am
Had me too, right upto the point he said 'old alfa engine out' :lol:
Postby owelly » Tue Feb 01, 2011 8:57 pm
See? I have been crafting stuff for Plastic Spastic!
Postby TeamTotalWankel » Tue Feb 01, 2011 9:07 pm
Good work :clap: Have you Artex'd 'em? :think:
Postby owelly » Tue Feb 01, 2011 9:09 pm
Yes.
Postby Jaffa » Tue Feb 01, 2011 9:28 pm
they will never make it anywhere near the car.
if they do, it will be undrivable. He needs one of the pedal to be wedged under the seat and the other two flapping around in footwell somewhere. Its what he is used too.
Postby fha772 » Tue Feb 01, 2011 9:33 pm
Is the Turd's floor strong enough to take that pedal box? :think:
Postby owelly » Tue Feb 01, 2011 9:40 pm
I took a piccy of the old pedals and used a paper template to see if the new pedals would fit. After ten minutes digging the leaves out of the car, I got the money shot. Then I noticed how spazzy the pedals were. No wonder it was like driving an At-at* that had been converted for someone with a severe disabilty.
*All Terrain Armoured Transport
