1978 twin charge saab powered reliant kitten
It was in the back of my mind that the holset might be too big to work with the charger . We were hitting 2bar manifold with the holset at 12psi but the fuel map was based on fuel flow to support 500hp and the estimator in the tuning software was showing around 450 hp but afr was mega rich going into the low 10s so pressure v flow is a long way apart and it really needs to run the later t7 trionic management which is maf based . Looks like I need to go with a gt3076r bb unit so the compound is on the shelf while I concentrate on the running gear for a while .
The other issue was the panhard rod flexing under boost and with the beam stripped out it was running a lot of toe in and positive camber on the o/s so spent a day getting it spot on and beefing up the centre to take a pair of triangulated link rods to make it a 6 linked set up
The front hubs which clocked up perfectly turned out to get well out of shape once the wheel was bolted on causing horrendous wheel wobble have gone in the bin with some nice chunky aluminium ones in progress .
Good things are the charge oolong system works well and temps were perfect although I didn't get much track time due to the brake issues . Spring rates are ok at the front but 450lb rears are going on the back and the car will come down another inch once I have massaged the front inner arches to make room for more bump .
To make use of the water meth system the map for the holset is a lot more agressive on the timing side as we have a lot more headroom with the 750cc injectors and the spray to cover any midrange knock from the extra advance . Have to say Im looking forward to the monster boost as we were probably only making around 300hp at Mallory based on what the holset flows at 12psi.
Next on the list is power steering which Isn't an issue at speed but for general hooning about will make catching the slide a lot easier and allow me to run more caster to get some self centering back
The corsa b column seems to be the easiest choice as the rpm and road speed signals are compatible with the Saab so it will be speed sensitive and torque sensing for some quick sideways action .
- froggy
Renrut - Posts: 4556
I looked at the mgf / mr2 systems but the corsa is plentiful and cheap plus the ecu is Mitsubishi so should be put together well .
- froggy
Relentless Rob - Posts: 5161
- froggy
froggy wrote:lots of mods this month , to start with the old hx35 is gone and made a good sum on the bay so the new hx35 hybrid cost £80 plus shipping . to get the best from it the manifold is being converted to split pulde including keepint the sides divided right up to the ext gate valve . after some mocking up im going up to a 44mm gate which has v band fittings and some adjustment for preload to help tuning .
the nissan manifold would be a mare to vut up completely so its being modified keyhole surgery style and the long runner that comes in at 90deg to the collecter has had a tweak to turn the tube ino the collector at a better angle
the corsa b power column is done and makes the car a lot easier to drive especially at low speed .the speed sensitivity works as it should and the weighting can be altered by adjusting caster on the top wishbone til i get some decent self centering but it feels pretty good as it is .
the floating felling from the rear is pretty well resolved now after tieing the lower chassis rails together underneath the car to stop the panhard rod mount from moving but it need a horizontal link on the n/s to triangulate the chassis properly . lifting the front trailing arm mounts up by 50mm has made a differnce to turn in as the back end starts to come round on the brakes rather than load the front into understeer .
the rear mudgaurds dont fit after adding the 20mm wheel spacers so no option but to fit the rear body so its back to cag and spray foam for a while
after smurfing everything i own last time ive got a roll of mask sheet to make a bit of a booth this time .
- froggy
getting a bit heavy to lift but i can still get it off on my own
the manifold is coming along nicely
the divider will carry on down the wastegate pipe right up to the valve to stop any flow mixing .
this runner came in at 90deg but now turns in a bit better
internal finish was pretty poor but it was a cheap ebay job
divider in place
- froggy
- froggy
Users browsing this forum: fha772, mitsuru, Renrut and 12 guests
