Very upgraded LPG Scimitar MV6 build
- loz
I was put off fitting a timing ring to the outer part of my crank damper for this reason.
I'm not being critical, just genuinely interested as I have yet to sort mine out.
Keep up the good work
Mark
- MarkV8
i guess the way of justifying it to myself.is that its been done before lots of times.
Time will tell
- loz
Its been done like this before (but then so had running an X30XE).....
It remains to be seen...
A little update then,
Nothing too exciting but its moving in the right direction.
Got hte oilstat through in the post and started to measure the hoses up. The pulley is being balances this week I can't really make a bracket until thats back on the engine.
The oil pipes have to go down to the chassis then up the suspension pillar to the oil stat which will be where the battery used to be. The exhaust is quite close to where the hoses come out of the block so some kind of heat shield will need making to protect them. The from the stat to the cooler through the now hole where the battery used to be. I cut up an old fuel hose to neaten up the hole, I'm quite pleased with how it looks.
Also put threadr locked the other side SS exhaust studs.
On another note, I made a little bracket thingy to mount the phone/mp3 player to a false tape, so the phone is there infront of you displaying the song/satnav right infront of the stereo. Photos of this to follow (can't photo it cos was using the phone).
More to come
- loz
Re the vibration thing a bit more, maybe its worth asking someone who does mapping e.g. Dave Walker, I'm sure he'll be able to tell you straight off if its gonna cause a problem.
My only thought is that even if its not moving by more than a degree or so, that'll be a degree or not of extra advance/retard on your ignition if its taking it instantaneously, not something you would choose to have.
Renrut - Posts: 4575
owelly - Posts: 6411
Got the hoses crimped to the right length on wednesday and picked up the newly balanced front pulley.
Trial fitted the hoses yesterday, mounted the cooler and oilstat and tighted up the front two hoses.
I'll leave the engine hoses off for now to give access to the engine while making the new CPS mount (todays task).
More to come
- loz
Basically made the sensor mount for trigger wheel pulley.
And here's where it goes
If its assembles, it foals on the trigger wheel (just didn't measure enough times), so I can use washers to get the spacing right, better too close than too far. I'll aim for 0.8mm I think, after the paint dries.
More to come
- loz
And tried it...
Now I've spoken too soon in the past, but I think it might just be WORKING
I'll tentatively connect other parts and keep trying it with my fingers firmly crossed that thats it. Its looking good at the mo though.
So I'm on the assemble now, first was the coil back on, but there were no front brake lines yet so I made up sone new (ish) ones that go straight from the master to each side, the bias valve thingy is no longer needed see (there is an adjustable one in the car now).
And they look like this
Not masses of progress toningt, but, all being well, a majorstep forward in overcoming a 9 month "glitch"
More to come
- loz
mjslonergan - Posts: 1362
To start with I thought I'd try my hand at boring the throttle body out, I thought I'd put it on the lathe to increase the bore then use a bit of bar with an angled top mounted in the lathe, with a sheet of brass screwed to it to make the new butterfly (see the pics).
Stripped the throttle body down first (a spare one I bought incase it went wrong
Then had a think about how best to mount it (turns out the best way would be on a milling machine but meh), I glued a couple of small strips of sheet steel to the bottom as the flat bas of the throttle body has one raised section. This way the flat bottom will be parallel to the face of the four jaw chuck.
I really should have had a photo of it in the lathe, it took a while to get it central with the dial gauge and make more difficult with all the machined surfaces being against the face of the chuck, so I had to kind of guess and centralise it off the cast inner surface of the upstream side. It came out well though, here you can see the right bore done and the left still to do
The slits in the spindle needed widening a little, this was a proper "farm engineering" job, I used a wood saw
This was the relatively easy bit done, the butterflies were the tricky bit really. With an increase from 54mm dia to 57mm the increase in CSA is 11% which should hopefully equate to an increase in power at the very top end of the revs.
I "umm'd and ahh'd" for a while about how best to make the slanted top bar for making the butterflies. Then gave in and used the workshop at work. Unfortunately I can't say I made the parts in the next couple of photo's but Dave in the workshop took the helm and did a fantastic job. First of all making surface grinding the bar to correct angle.
This was mounted in the lathe and the butterfly turned so that it would come out with slightly slanted side to seal in the body at 4 degrees.
The Spindle has also been countersunk and smaller machine screws bought
This is when I found that the way the body was clamped in the four jaw chuck (using only two jaws) had meant that the bore were 0.02mm oval
Next I had a go at the idler puller (was the PAS) I wasn’t too happy with the wobble it had, so I got a new bearing for it (was the timing belt idler bearing), but this didn’t cure it, the problem being that the PAS pulley is much bigger diameter than the timing belt idler would have been so any movement in the bearing is very amplified by the size of the pulley. Long story short… I put a second bearing in with the first, right next to it, so now there is no movement sideways at all, you can just about make out the extended hub of the pulley in these photos.
Another little project was to make a little section of electricery for the front of the car with some relays, a resistor and the slow start jobby for the interior blower.
Another little job was to fit an adapter thingy that means I can have the oil pressure gauge and the low oil pressure warning sender both attached to the oil system. I’ve wired this up with the oil level warning sender and the coolant level warning sender into a circuit with a little relay so that if anything out of order a buzzer sounds (which can be silenced when starting the car with a push button)
The new oil lines go pretty close to the exhaust manifold, so I think I’m going to get them ceramic coated (as this will help with corrosion too), but in addition I’ve made a little heat shield mounted on the exhaust manifold that goes between the pipes and the… pipes
I had to have the manifold off again to further grind out the throttle body mounting point so there is no lip between the throttle body and the manifold.
The MAP sensor was neatly mounted on the engine, tucked away, turns out they don’t like heat or vibration so that’s packed up already and I had to fit a new one on the side of the engine bay.
Got the axle off (again) and started to strip it in an attempt to change the diff to the quaiffe item.
Got the drive flanges off and put the sacrificial one on (the bent one) complete with half shaft puller (chain and jack)
And just three snags of the chain later…..
Took the diff out and took it to work and took the accurate measurements, only to figure out that its really b***dy difficult to get the bearings off, and I’m still at it.
In the mean time This rear disc conversion is available if anyone fancies it. It includes the caliper mounts made by Sam Laurenzelly (I think that’s his surname) who was a scimitar man not so long ago and started the V8 Church website, the audi calipers will come with it and the spacers of different thicknesses to get the disc in the right place, the calipers have been modified to accept the scimitar hand brake cable. So all that would need finding is new discs and flexi hoses (they’re not included).
Bear in mind that these weren’t quite strong enough and put a little too much bias on the front brakes, so something would need doing about that. This conversion would work really well with a front brake conversion (if smaller piston calipers were used up front).
Over the last couple of days I’ve been busy getting all the wiring squared away, the LC-1 is is connected and giving a proper lambda ratio reading through the Canems ECU, the LPG ECU is fully connected to the Canems ECU and tank, but not yet the other LPG components, and the front end loom is back in the left wing. The engine is running perfectly with the fault not having shown is face again, and the idle is much sweeter now its not 18 AFR.
More to come
- loz
Users browsing this forum: Renrut and 10 guests
