Or make a fibreglass roof panel.
Or just make an sheet with a folded lip and rivet it around the lip that the old sunroof had and use seam sealer or similar to seal it up. Will look cack though.
Will do my car's ever look cack?
Relentless Rob - Posts: 5153
If I have enough time tomorrow I'll get the car taxed and a proper road test.
More photo's later. I have some work to do first.
So in the cold light of day she's a bit of a shed. :rolleyes:
The usual rust spots...
...nothing to worry about.
Also showing signs of the cars age...
...bent rear bumper (invisible car syndrome)...
...had a look underneath to see if the braket was salvagable...
...and found more rust.
Whatever cracked the headlight...
..also broke the grille. Possibly a Pheasant or Grouse. A very unique Tartan interior...
...most important I managed to get the heater working. The contact points of the switch were dry. I'll give the car a wash and tidy up tomorrow as it's half term and I have been distracted by little people today.
[/url]http://www.scotlandshop.com/tartan.aspx ... rtan-13076
Handy on case I need a re-trim eh?
I'd like to take the Panda to the run what you brung day at Santa Pod. Do I take the car as standard or start modification right away as the £999 Challenge is in June and I'll be pressed for time?
Subtle.
Gratuitous washed the car today photo'....
... £300 very well spent.
Ordered a pair of bulbs as a back up and dug my driving lamps out of my shed.
Relentless Rob wrote: it still has the Lucas LLB012 H4 headlight bulbs.
All uk pandas came with the llb 012 non halogen bulbs right up to 95. Halogen replacement are avaiable but the most important bit is to make sure the earths are good. I find the best trick is to cut off the spades at the earth 'hedgehog' and use large ring connectors bolted to the earth point. Also never run on just sidelights, it will burn out the switch due to a switch design fault.
- sportpanda
Users browsing this forum: No registered users and 12 guests
