Using a £999 car as a daily worked out pretty well my E36. Apart from being asked not to park anywhere near the front at work that is.
Relentless Rob - Posts: 5173
So what of the red pandas suspension do the cinq bits fit?
- Steve33
Steve33 wrote:Its moted till later in year its not considerd classic so no cheap insurance hence 600 I might try temp for a month as for the leon It does me 66 mpg on work duties up n down m4 and its good for wafting past lorries . I get 540 off a tank .
Hmm.... I am 100% with you on 'wafting', M8
People talk about 'fast cars'.... and why not! However, some people don't quite grasp that a FAST CAR is good, in mixed traffic, for maintaining a 'not intergalactic rate of knots' over the journey overall.
My works 105HP Doblo Van blows the door off quite a bit of fancy kit..... but it REALLY does the business simply wizzing past strings of HGV when I'm up the A1, in Northumberland.
PASSING is not SPEEDING... it's "not staining the oncoming traffics' underwear" - or MINE
tooSavvy - Posts: 536
http://www.ebay.co.uk/itm/200738721374? ... 720wt_1363
...originally designed for a post millennium Neon the inner diameter of sleeves are 50mm. The have various sized locking screws and easily fit the 47.5mm roll cage tube. So if they are to big for the Panda shocks I can use some of the off cut roll cage tube to make them fit. Springs designed for a car that weighs 1.5 Ton in a car that weighs 700Kg should be nice a firm. Plan "B" involves a Neon that being fitted with a V6 at the moment.
After a little more investigation the water pump was held in with silicone and the even though the gasket between the head and the cam's was new and the bolts were also the old head gasket had been reused and there was radweld type stuff blocking one of the water channels.
So it looks like the 1368cc block had a 1242cc head fitted after the water pump failed. The water pump and head were bodged into place.
So do I continue with the 1108cc engine in the shed that has the distributor ready to go or do I fit the 1108cc head on to the 1368cc block with distributor and x/1-9 carb'?
The 1.5 carb' would need very little adjustment to suit the set up and if I clean the ports of the head before fitting it and fit the Punto 75 cam' it probably wouldn't need adjusting at all.
What do you guys think?
Using the actuated pulley from the air conditioning pump and the old heater matrix controls to operate a flap in the air intake to go from n/a to charged. I can even use the heater switch. Stealthy eh?
mjslonergan - Posts: 1358
At least in theory.
mjslonergan wrote:I was more thinking it might break up, as Fiat were not really known for overengineering a lot of bits
This.
Heater flaps tend to be very cheap plastic. I'd not really trust that to stand up to much boost. Old throttle off something should do the job nicely though. Don't some superchargers have built in bypass valves anyway?
Renrut - Posts: 4564
Using the levers, cables and making my own flap, not the plastic flap from the matrix itself. That would be silly.
I'll M.S Paintshop it later.
So with the actuated pulley from the air con' unit wired to a switch on the dash, and a cable from the old heater matrix to open and close the flap to go from N/A to charged. Looks fairly simple and may even work.
