Monte brakes.....
In 1977 the Lancia Montecarlos were reknowned for having poor brakes, so you can imagine how they feel 35yrs on, and it now has 150BHP which doesn't help
A while back I upgraded the fronts to 240x20mm Uno turbo discs and used Ford calipers as these happen to have the same piston size as the originals. This stopped the horrendous brake fade / fluid boiling but didn't really add to the overall stopping power. The 240's were chosen to fit inside the std 13" wheels. I've now got 14" wheels so have a bit more room to play with
ETA, a quick google suggests the piston are 30mm.
owelly - Posts: 6410
owelly wrote:The correct answer is for you to make the ally carriers out of the correct grade of ally. I made some for my mates rally car out of some random bits of ally and even though the tapped holes were quite near to the edge, they're still going (stopping) strong after several rallies. Those Diahatsu Applause calipers I have used are tiny wee. I can whip one off the car tomorrow to measure the piston if it pleases you?
You sound just like that bloke off LCB
I'm considering some random ally too. The forces involved here aren't really gonna be that great. If it was a 400bhp+ 4x4 running slicks then maybe I'd be looking at a way to machine 'Unobtainium'
PS. Where's jaffa, does he want those wheels I offered him?
Failing that you could always give Hi-Spec or OBP a call.
Relentless Rob wrote:Can you raid the parts bin again? Lancia Delta HF or 'gralle, possibly something newer like the Brembo four pots from the Fiat Coupe.
I'm raidng the bin for the rear discs, they're from a 93-99 Punto (257x12mm). I'm happy enough with the fronts for now and have to be wary of the piston sizes on the big 4 pots.
Relentless Rob wrote:I have a pair of N/A 16V Fiat Coupe rear calipers in my shed you can have. I'm not 100% sure but I think the disc are either the same size or the same as front Cinquecento ones.
Ta Rob, but with 34mm pistons they're not really what I'm after.
Anyway, that was a frustrating evening!!
I based my calculations on internet date about the discs. It stated the Monte ones were 50mm high and my new Punto ones were 40mm. This gave me a nice round 10mm to make my bracket from and everything would fall into place. My new discs arrived today and I got a nice piece of 6082 alloy and set about making the bracket. Spent all evening cutting / drilling / tapping, and I was quite pleased with the end result
So I've reverted to 6mm steel and got a 2ft bar of 6x50mm for £3 from a local engineers
Got a go at it this morning-
Here's the discs for comparison-
Managed to turn this into this-
Because of the closeness of the hole I had trim the point off the bolt head once it was torqued and loctited in place-
And a bit more trimming for clearance-
And all in place
Just need to do the other side before I can go for a road test.
Rippthrough - Posts: 1086
Rippthrough wrote:Why not just use a couple of cap screws?
Tried that, but they still needed 'trimming'. So chose to stick with the hex heads as they effectively become semi-captive when in place, making installation a lot easier
Spent yesterday doing my front 'big' brake conversion-
Bracket in place and some minor (few mm) 'shaving' of the hub assembly to allow for the extra 4mm of back spacing of the new 257mm disc.
Only took it out for a quick test drive as the pub was calling me, but even before they're bedded in I'd say there was a BIG difference. The nose actually dips when I press the brake which it never did before!!
Users browsing this forum: No registered users and 8 guests
