Useful Engine + Gearbox weights
http://westfield-world.com/engineandtransmission.html
Lots of info on various engines for use in westfields which is also handy for me as a lot of that kit is used in making a fast midget.
bottom line is K series with type 9 ~ 120kg
Renrut - Posts: 4564
3sge 133kg
ALLOY BLOCK Mi16
Engine weight (dry, no flywheel) 112.6Kg
Engine weight (dry, with flywheel) 121.6Kg
Engine weight (dry, with flywheel, alternator & starter) 132.7Kg
Ford 2.0L duratec is aparently rougly 100Kg including anclis, flywheel and sump
sr20de high port and tranny 170kg
http://www.gomog.com/allmorgan/enginewe ... tml#engine (link includes some engine dimensions)
1 lb= 0.453592kg
- DiYMCRT
Its a good list but its a little confusing I think in terms of what ancillaries are attached.
I plan on weighing my K once I've got it fully decked up with all ancillaries and flywheel + pressure plate. But I can dead lift it myself as it is (assembled block/head + timing gear, minimal oil) so can't be more than about 80kg at the most.
- M52E30
M52E30 wrote:Can't say anything for the rest of the list but the BMW data doesn't seem accurate. M60 is a V8, not a small six, an M52 is not a big six, that's the M30 - the weights look about right for an M30 but there's no way an M52 is anywhere near that weight...
Still sure about thaT?
But seriously that list needs to be taken with a pinch of salt. The westfield one I posted seems about right though.
