It is currently Wed May 22, 2013 3:19 pm
Cleaning valves?
Postby MrT » Thu May 03, 2012 10:28 pm
I've got the valves out of my MG ZS and they need a bit of a clean. To be fair they aren't that bad but whilst I have the head off I may as well give it all a good clean.
What is the best way to get the carbon off?
MrT
Postby owelly » Thu May 03, 2012 10:48 pm
Pop the valve in your drill chuck and apply a bit of emery paper to the spinning valve.
Postby TeamTotalWankel » Thu May 03, 2012 10:53 pm
Mind those seats tho :wink:
Postby Relentless Rob » Thu May 03, 2012 11:08 pm
What they said. I've found a pillar drill and wet and dry sand paper soaked in WD40 works well.
Postby MrT » Fri May 04, 2012 5:07 pm
Cheers :thumbup:
I'll give that a try tonight.
MrT
Postby TeamTotalWankel » Fri May 04, 2012 6:04 pm
MrT wrote:Cheers :thumbup:
If you don't have a pillar drill then pop your drill in the vice or clamp it to the bench.
Postby MrT » Sun May 06, 2012 5:43 pm
Worked a treat, I have a clarke pillar drill thing you fasten a normal drill into. I found it easiest with this tilted on its side:
MrT
