Mounting a camera in a track car
I've been pondering how to mount my digital video camera in my Merc.
At the moment I can see 2 options,
1) buy a tripod and ratchet strap it into the rear of the car, where the back seat was.
2) make a steel mount that bolts to the tunnel, with 2 stays back to the top rear seat belt mounts.
How would you mount a camera in the car?
Cheers Frank.
fha772 - Posts: 4953
owelly - Posts: 6411
Mounted to the mirror with a rubber band to the mirror is a bit shakey and the suction cup holder won't get past the aliens from the panlet Scruton. The camera I've bought has a mounting for cycle handle bars and I'm hoping I can use a longer band and wrap it around my cage.
Relentless Rob - Posts: 5177
fha772 wrote:It's just a small slimline digital camcorder with a fold out screen, not much bigger than a phone when closed.
Not like the Russian ones that Del Boy had on OF&H then??
Thinking we'll screw something to the dash this time (with a car worth a few quid you may not want to swiss-cheese the dash but at least with our Astra we dont care!), having less of the car in shot would seem a good thing but I think it takes it out of context a bit & you got to see the top of dash & screen pillars with further back where it was before. But having it record something worthwhile instead of the wait to go out seems worth that compromise.
Watch a few vids on youtube & see which point of view you prefer then see how you might mount you camera there?
