Mx5 tdi
owelly - Posts: 6409
If you must have diesel power for your MX5 how about a BMW 318TD with a Holset turbo and front mounted intercooler?
As it's a car engine rather than a tractor unit it would suit the platform better, less faffing about and spares would be available more readily.
You'd need to keep the transaxle box and swap bellhousings and bits over to the Mazda box. At lest the BMW is already a rear wheel drive platform and therefore less of a pain in the cheeks.
I like the look of that.
Back on topic(ish) this is another coupe that's been ruined...
http://www.ebay.co.uk/itm/FORD-PUMA-ESC ... 4d0169591f
...having said that a more refined Mondeo TD or Dura-Torque with a JCB or Holset turbo would be an interesting proposition.
Not sure of I should like the MX5 based thing or not. Is it trying to be a Ferrari?
- DaveRoverMan
its in the bath in PPC, get some beers down your neck, get on ebay and make it happen!
Renrut - Posts: 4559
Ebay mobile clicky
Or Item #230808118359 for those who want to see it on full size eBay.
- DaveRoverMan
Unfortunately... they weigh approx 500kg, and make the 300kg jag v12 look like a paperweight! But.. that does just about fit in an mx5
The vw TD engine is an awesome piece of machinery - shove the right pump, injectors, and turbo on, and you'll see an easy 250bhp+
- Chairchild
