Throttle Bodied Clio
Matt
- stealthstylz
I already had a lot of the parts lying about in the garage, plus a desire to learn new tricks so when I suggested I put throttle bodies on it I found a suggestion that my girlfriend agreed with, and so it began.
Spud
- spudmurphy
- Captain Haddock
Matt
- stealthstylz
I got the replacement brake lines in, they fit OK, not as good as I would have liked and maybe I'll do them again eventually but they'll do for now.
Master cylinder end
General view, you can see whre they get a bit untidy
A couple of brackets needed modifying for clearance, did a good job of these I think, and sprayed them black while they were out [:)]
A couple of manifold shots
Nice welding [;)]
Started to remove ALL the renault ECU related wiring, loom from the ECU here broken out of all the protection so I could see what needed to stay and what could come out,
Eventually got all this removed
Next 2 pictures were all that I left in the engine bay, top one has all the lights and stuff in, bottom one is the starting/charging wires loomed together again.
Throttle bodies back in with Injector and TPS wires loomed
This one has old renault loom at the bottom, my loom at the top where the coolant temp sensor and Lambda wiring join
And lastly for now the wires so far that need to go into the car for he megasquirt.
I still need to fit the coilpack somewhere in the engine bay and wire it in, adding the EDIS wires to the loom into the car. I also have all the bits I need to fit the oil temp/pressure gauge on order so that'll be going in this week.
Spud
- spudmurphy
- browser
An easy jumpin power is to fit the 1.6 bottom end from a megane with the energy engine They're pretty much a straight swap and offer the obvious increase in capacity. The head to get though comes off earlier energy engines as found in early clios, or the 19 [:D] A port and polish job on the head works wonders, when I swapped the head on the clio it gained a bit over 10bhp !!! and that was on (almost) back to back RR days !
Spud
- spudmurphy
Added to which the scrapyard nearest me want £20 per used/scuffed/road-soiled alloy so they can sod off!
ANyhoo, I looked under the bonnet of a Megane and was suprised to see a 1.6 Energy engine, complete with multi-point injection, which then got me thinking[:D]
I am intending to leave the lump more or less like it is now, apart from trying to free up the breathing a litte with a less restrictive air filter arrangement and maybe try and flow the throttle body a bit. This plus the planned 4-2-1 exhaust fannymould might see me breach the 100bhp barrier? Exciting? Not 'arf!![:p]
- browser
Is there much of an internal step where the hose ends and the TB's or manifold start?
Did you find it diffcult to bend the hose to match the spacing of the TB's to then head?
What supports the weight of the TB's? just the hoses?
Thanks from someone doing something similar, somewhere.
- crogthomas
In answer:
<i>The silicone hoses that you have used to join the TB's to the manifold, are they reducers or a bit of straight hose that you have stretched to fit?</i> - They are reducers.
<i>Is there much of an internal step where the hose ends and the TB's or manifold start?</i> - At the manifold end there isnt much of a step as I had to turn the tubes down for the joiners. At the tb end there is approximately a 4mm step (the wall thckness of the tb's)
<i>Did you find it diffcult to bend the hose to match the spacing of the TB's to then head?</i> - In a word... Yes! the outside runners on the inlet manifold are angled inwards, but they should have been more I think. But they fit fairly well for now [:)]
<i>What supports the weight of the TB's? just the hoses?</i> - Yes, just the hoses for now. I think it should be plenty, the bodies dont weigh much and the whole set up as very stiff.
Ta
Spud
- spudmurphy
The main progress has been getting the EDIS set up in. The main bit of this was getting a trigger wheel stuck on somewhere, and mounting a crank sensor somewhere near it. The trigger wheel was easy enough, but the sensor bracket took a few goes [xx(]
I got there in the end though, and it looks something like this.
I've also made a bracket and attached the EDIS module to the nearside turret
Spud
- spudmurphy
- Evodelta
Spud
- spudmurphy
Users browsing this forum: Renrut and 10 guests
