The buggy thread
Rippthrough - Posts: 1086
Just packing up now to head for the event this weekend at Waterbeach - complete with warm sunny weather for a change!
And there were a lot of big power 4wd guys there today, so pretty happy with that!
Would have been 8th but the throttle cable snapped 200yards from the finish line on the very last run, and we ended up finishing 4 seconds behind the bloke who was 8th, doh!
They're not revalvable though - sealed units - so I've altered the shims and pistons in the Fox's instead, as they're cooler running anyway.
Should have a bit more traction over the rough stuff and be a lot better landing and taking off over jumps, hopefully.
Stripped the rear calipers down and rebuilt those as they were sticking a bit, had all the nuts and bolts off the drivetrain and suspension and renewed the locktite as it tends to soften up after a few events.
Front upright has had a couple of new bearings again and a sleeve on the shaft to take it up to the next size bearing - see if we can get them to last longer than a season!
Also sorted out the number board by taking off the top where it looks bloody ugly and putting some proper stickers (thanks to Adam!) on the side of some Carbon/Kevlar panels on the side of the car.
Tweaked the airbox to get another litre of capacity in there just for a touch easier breathing for the engine, and sneaked a bigger filter in so it doesn't get clogged up as fast with the dust and mud.
Fitted a new torsion bar in the front end and taken a bit more load on the springs so the bars aren't doing quite as much work.
Other than that, just routine maintaince - oils/filters/water/grease bushes/regass dampers.
And ready for the next race next weekend - novelty being ready this early for us!
Big problem with a heat-related misfire though.
