It is currently Wed May 22, 2013 7:23 pm
For Sale: Mazda 13B Rotary
No commercial posts or advertising please, these will be deleted without warning
Postby majic79 » Wed Nov 09, 2011 10:32 pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0639851201
a reasonable offer will be considered - was going to be used in an old skool project, but since I can't use it for Road Rallying, I'm going with something more conventional
majic79
Postby Renrut » Thu Nov 10, 2011 10:49 pm
What sort of size is it? I've never seen a 13B for real. I've heard they're quite small. How small is quite small?
Postby majic79 » Fri Nov 11, 2011 12:24 am
Hmmm, I reckon the gearbox for my Polo is about the same size.
Imagine a 1ft cube, make the top face rounded (downwards) and elongate it an inch or two and you're there. I'll measure it up properly on Saturday when I'm back in the garage. It's light weight, probably less than a K-Series
I was hoping I could use it in a road rally car, but MSA says no :( (Specifically, the rule says "One wankel unit will be classified as three cylinders." and as there's two of them to make up the complete engine, the engine is banned under the "no more than 4 cylinders allowed" rule)
majic79
Postby Renrut » Fri Nov 11, 2011 10:03 am
So pretty compact then. What sort of weight is it?
I'm considering my options for Salami as this V-twin is such an awkward shape to fit in to anything except a motorbike. The 13B is about 150bhp isn't it?
Postby majic79 » Fri Nov 11, 2011 12:58 pm
It really depends on the engine - the turbo'd lumps made astronomical power, the N/A's are a bit more conservative. The early cars are around 130hp and it just goes up from there
I think bridge and peripheral ported engines can rev astronomically and make in excess of 200hp in N/A guise
http://www.rx7club.com/showthread.php?t=809124 - claims of 280hp at the wheels with a 9600rpm limit. There's also a dyno plot of a 210 hp engine with some additional pictures
majic79
Postby majic79 » Fri Nov 11, 2011 1:15 pm
Weight of the engine: 180lbs for the core engine, the ancillaries will add weight naturally
http://www.rotaryaviation.com/faq.html#weight
majic79
Postby Relentless Rob » Fri Nov 11, 2011 1:50 pm
N/A 13B's love superchargers. The nature of the progressive boost suits the characteristic smoothness of the power output.
Just in case Will needs any further convincing. :wave:
Postby Renrut » Fri Nov 11, 2011 6:14 pm
Just read that thread on rx7club - there are some crazy people on there.
I was under the impression they could rev a lot higher than that so I'm surprised that people don't have them revving into motorbike engine territory.
Postby majic79 » Fri Nov 11, 2011 8:12 pm
there's a few limiting factors, but I suppose you could take it to 10k easily on carbs, they lack torque low down though, with staged fuel injection and peripheral porting you could overcome the limitations and get the thing to go to 16k or so!
If I could have used it for road rallying I'd be doing just that (MSA says no :( )
majic79
Postby Renrut » Sat Nov 12, 2011 3:29 pm
I confuses me that they don't run a set of slide throttles at the ports to give low down torque and high rev performance.
Postby majic79 » Sat Nov 12, 2011 5:48 pm
they do have slide ports - it's called the rotor!
Measured it up in the garage: 19" long x 16" tall x 15" wide
majic79
Postby Renrut » Mon Nov 14, 2011 12:14 pm
No. From what I've seen 'camming' the wankel effectively raises the power peak rpm at the detriment of low rev power. This is done by opening up the size of the ports in the housing - bigger gives higher RPM performance. What I'm suggesting is a slide throttle over the ports changing the size of the opening depending upon the rev range in which you're operating.
That's a pretty tiny engine! Does it have a fairly standard gearbox mounting face?
Postby majic79 » Mon Nov 14, 2011 2:00 pm
Renrut wrote:No. From what I've seen 'camming' the wankel effectively raises the power peak rpm at the detriment of low rev power. This is done by opening up the size of the ports in the housing - bigger gives higher RPM performance. What I'm suggesting is a slide throttle over the ports changing the size of the opening depending upon the rev range in which you're operating.
Ok, I've not really looked at it, my plans got scuppered when I learnt that the MSA had banned them from road rallying, so I stopped looking into it.
Yes - I forgot to have a look for the original gearbox this weekend, but I'm back in there tonight, I've been assured that it's in there somewhere, probably under a pile of metal/tools/rags!
majic79
Postby majic79 » Mon Nov 14, 2011 3:01 pm
Yep, it's definitely in there - I'll drag it out this evening while we're in there - no garauntees on condition, but it'll be bundled with the engine to the winning bidder
majic79
Postby majic79 » Tue Nov 15, 2011 10:21 am
Well, foudn the gearbox - it's fine, still got oil in it (no water!) and turns over nice and clean (couldn't feel any backlash in it)
Didn't meet the reserve on ebay (£100) so I guess it's not as valuable as I thought. I need a car to put it in, I wonder if I can convince my mate with the Datsun 120Y that that'd make a good car....
majic79
Return to For Sale: Selling a bargain, want a bargain?
