Long term 5 door Sierra LX project
With a mortgage, two kids and a Wife to keep happy it's going to take a while to finish
Pics below represent 18 months of work in my spare time and 5 years of parts collecting!
Started with this
I pinched the engine and sold the rest for scrap
A
pair of these will help it breath
Fast forward a few years and I bought this rolling shell with 2WD Cosworth axles and diff.
After some nicer wheels
Wheels got stuck in the loft for safe keeping.
- MarkV8
The bell housing does not fit my engine though and the correct one from the U.S was $600
Plan B was to get a bellhousing for a different gearbox and make it fit.
T56 is the short one.
Out with the precision marking gauge.
Stone cutting wheel in a side grinder did the job.
I had a piece of ali welded to it and then borrowed the CNC machining centre where I used to work.
No where for the clutch fork to go now so this will do the job.
- MarkV8
Are you keeping it stealthy or going for side-exits?
Some more pics of progress so far.
I had some header flanges water cut and TIG welded some stubs in.
Some bits from OJZ engineering
I tacked it all together and then took the header pipes off to weld one at a time.
Several months of spare time condensed into those pictures.
More to come.
- MarkV8
I'm going to get it painted frozen white and will probably just have a Sierra sticker with no clue to whats under the bonnet
Some more of the goodies I've been collecting over the years...
331ci - 5400cc stroker kit with steel rods and forged pistons along with Edelbrock Performer RPM intake.
Just fits under the bonnet
Next chapter is fixing the bodywork.
- MarkV8
On the spit
Sorry about the pics but this site seems to chop the right hand side off some of them.
That's as far as I've got with the Sierra in the 18 months I've owned it
Any updates will seem a bit slow in coming as scraping and grinding the bottom of an old Ford is soul destroying and time consuming.
It's going to be 100% road car with sound insulation, ABS, heated screen etc etc.
thanks for looking!
Mark
- MarkV8
bulletproofbob - Posts: 1845
I've been welding up any nasties as I go.
After days and days of work it's getting there
Trying a lazy way to clean up the front hubs...
Will leave it to brew for a week and then give them a look.
- MarkV8
Looking good though.
Relentless Rob - Posts: 5154
