TeamTotalWankel - Posts: 2355
This a precision piece of engineering...that just happens to be made out of a lampost
It seems to work with Lego.....
owelly wrote:Hmmm, I hadn't thought of that Will........ I mean, I've never been much good with technical stuff.
I once explained the idea of PCDs to a guy. Only to find out that he was a mechanical design engineer and the last job he worked on was the track system for the Challenger 2. His own fault really for being sarcastic
"so Owelly, you know about hydraulics?"
"oh, yeah Kev. I do them all the time."
That sarcasm also backfired.....
I splashed a bit of paint around my bits of metal the other day and planned to get the subframe, diff, driveshafts and brakes all assembled this afternoon, then tomorrow, I could 'glass up the big hole under the back of the car and make up the mounts for the new fuel tank. By end of play tomorrow, I wanted the Turd back on its wheels and drivable.
So two hours looking for the long bolts to hold the diff in, then a break as I had to fix SWMBOs A4 and take the kids to the park. As it now gets dark an hour later, I could still be on schedule by morning. Then I spotted a wonky slider pin on one of the calipers. It had been snapped and then brazed back together. So now I need to find a 13.8mm dia slider with a m9 (wtf?) Thread. Or fire up the lathe.
Stay tuned to find out if I've glassed myself to the driveway...
