Domestic Short-hair
So I'll do that tomorrow if the auctioneering doesn't go well tonight.
Found that Mountune do a racing Jaguar V6s:
http://www.mountune.com/Racing/Engines/jaguarv6
Obviously not ideal for a 1600kg road car. I might give them a bell at some point and see what they can do regarding road cars.
I found the old Pistonheads link regarding the V6 and Nobles modifications that allow them to handle up to 500bhp:
http://www.pistonheads.com/gassing/topic.asp?t=973036
And the manual gearbox is a Getrag 221 although I'm struggling to find a max torque for it - some web hunting suggests 245Nm but the V6 normally kicks out 280Nm peak. I know peak and continuous aren't the same thing but that sounds quite close to the limit already.
Renrut - Posts: 4558
I've swapped the tyres round front to back to give me plenty more on the rear so I don't end up with bald tyres for the drive home.
Hoping for low 15s over the quarter.
Planning for the future I've done some research - STR brakes will fit and use braided hoses as standard. This should be a direct bolt on swap. But I will need 18" wheels to clear them as my 16s only just clear the ones I've got. I've seen sets of 2nd hand but usable STR brakes going for about £500 inc discs and pads. Set of 18s with tyres will be about £300. Something to consider after I get back from holiday when the finances aren't so tight.
1 - tune the V6, maybe turbo it a la Noble ~400bhp but £2-3k by the time i've got 2 turbos, manifolds and done all the pipework, block mods and setup.
2 - fit a V8, jaguar did a 4.0 V8 model as standard with 280bhp but it was auto only. It does mean all the mounts etc and positioning of stuff will be ok without any headaches. So I could just fit the V8 to the manual gearbox. Adaptor plate and a different clutch setup will be needed. ~ £2K tops by the time its setup even if I have to get an aftermarket ecu.
3 - give up and buy a 400bhp STR and live with the Autobox - £5K minus whatever I get for mine.
4 - yank V8, not really thought about this much but having seen how compact they are I could fit one easily. Will almost certainly need a new gearbox to handle it. Corvette / Mustang drivetrain would get me gearbox plus engine. No idea how much though.
5 - Nitrous a lot. £500 to get it sorted which probably safely gives me 300 bhp.
Any thoughts?
Relentless Rob - Posts: 5162
The other option I didn't add on was getting rid of the jag and buying a TVR Cerbera. I've fancied one for a long while. at 10K I figure by about this time next year I should be able to afford one and that gives me around 400bhp, 500kg weight saving, a manual gearbox and tiny back seats that I'd never use anyway
V6 into the midget has already been thought of. Lots of shell cutting to make that fit under the bonnet although I suppose the whole rear subframe could just be bolted on to give me an IRS rear end and a diff that can handle the power...
No, I must get it on the road first!
The tyres seemed to be the main failing, even straight after a run they were stone cold. The silver lining is that they didn't appear to have worn any worse for the treatment. Too bloody hard basically.
So if I go again it'll be stickier tyres a necessity.
In other news I've finally managed to find someoen with those camber bolts at a sensible price - £20 delivered! 2nd hand from the local breaker, he finally had an S-type in again. Much better than the £120 from Jag or anyone else who would sell them. They should turn up just after easter. I'll get them fitted at that point and hopefully get the alignment sorted once and for all.
Renrut wrote:Nothing much to report, the RWYB went ok. Ran a best of 16.2s @ 86mph.
That's as fast as my stripped out E36 was and you had 600Kg more to push up the strip. Good show.
They then flatened the battery while I was at work thanks to Jaguar's clever auto wiper parking system having a unswitched live to the wiper to park it when you take the key out. Of course if its jammed in the unparked position it keeps trying until it flatens the battery.
Jump start and wiper fuse out and it started and drove no problem. Removed the wipers, mechanism and motor last night. Mechanism siezed solid (steel spindle in ally frame) so thats gone in the bin. New mechanism from Jaguar = £150 + VAT. The motor is more
So I'll be picking one up from the local breakers tomorrow morning on the way to work for £50 inc motor. I use these guys - http://www.jojags.co.uk/ always helpful and really supportive of the DIYer!
mjslonergan - Posts: 1355
It made me think that perhaps there is something better than wipers out there - perhaps an exhaust powered hairdryer to blow at the screen. Or maybe just design a blower assisted engine bay venting system that can force air up the screen even at a standstill.
The linkage and motor were quite heavy. If a simple blower and duct system was effective then it would be a big weight saving. But I'm not sure it would work well against dirt and grime unless it was pressure washer level strength. This idea needs more thought...
Turn the washer nozzles into pressure washers and have some sort of industrial dryer plumbed into the scuttle. This might work. Dunno if there is a legal requirement for wipers or if anything else that does the job would do...
The OH is trying to persuade me to buy her car off her so she can afford a new one.
Users browsing this forum: Diamondgeezer and 10 guests
