Midgets with (Pan)hard rods?
But all the panhard rods I've seen have been rose bushed even on road cars. Won't this introduce lots of vibration or will it simply not be transferred as its not as tightly bound as a typical wishbone?
Or would a different setup be better? I've looked over a lot of the setups and they all look a bit extreme, although I may change my mind when I flip the car over to do the underside.
http://www.frontlinedevelopments.com/products/midget/panhardrodkit.shtml
Pricey for what is essentially a long rod, a couple of rose joints and some brackets.
But then it will save me a lot of dicking about with suspension which isn't something I'm fond of
General consensus from trawling the various midget forums seems to be that:
- a well setup 3 link rear end is much better than any fancy 4 links due to weight saving,
- watts and mumford linkages are heavy because of all the extra braketry you need and doesn't give much better than the lightweight panhard setup,
- removing the LA dampers is worth the effort unless you're tied to some racing regs and is very easy to do DIY,
- designing your own is a waste of time as no matter how clever you are someone will have already tried it.
No one ever seems to have anything bad to say about Frontline other than they're a bit pricey.
You should always cost in your own time, and at a high rate, theoretically I am a multi-millionaire, if only I would pay myself...
Relentless Rob - Posts: 5153
