Saxo 2.0 Zetec
Renrut - Posts: 4577
If you happen to have a Zetec, Saxo and reel of Duct Tape give it a go but you'd be better off fitting a 406 V6.
Relentless Rob - Posts: 5187
Relentless Rob wrote:better off fitting a 406 V6.
Won't that handle even worse?
I know on the xsara the 2.0 is shoved well back in the bay to give decent handling but it is a wider and bigger car than the saxo. The v6 would put more weight out front...
I think a saxo 1.5TD would be awesome with the boost wound right up and using compound charging to keep it vaguely drivable
Used to sit pretty in the 205. If the Saxo is dramatically different get your grinder out and stick it in the back.
There I go solving problems with a grinder again.
