Discovery LWB
Get one with chassis rot.
Buy a brand new galvanized chassis, but have it made with a 125 inch wheel base.
Chop body shell in half, fit front to the front end of the chassis, the back to the back, fill the gap, fit Defender 130 rear prop.
Replacement for Kevin Leaper's Range Rover Classic, as the PPC parts chaser/tow truck?
- ACE
http://www.ebay.co.uk/itm/Range-Rover-c ... 27c8ec552c
Btw, I suspect this is a converted fire engine, despite what the seller states, Carmichael marketed it's estates as Clansman, Commando's are all fire engines (afaik).
The missing history might explain this, a call to Carmichael themselves (quoting the Job no.) might confirm/contradict this.
Amdac Carmichael...
Tel: 01905 420044
Fax: 01905 420120
Carmichael Support Services Ltd
Tel: 01905 748660 or 748661
Fax: 01905 748662
Or bang on the door @ Amdac Carmichael, Weir Lane, Worcester, WR2 4AY.
(Come off the Bromwich Road (A449) along Weir Lane, past the houses and into the industrial estate, past Travis Perkins on your left, take the next right (still Weir Lane, sounds odd but you'll see when you get there), Amdac Carmichael is on your right. If you get to the Worcester Citizens Swimming Pool, you've gone too far.)
- ACE
ACE wrote:Or buy this...
Fingers crossed for a Lottery win ... probably means I need "to be in it to win it" though
- brickie501
Also, you'll be doing well to find a Disco I with a good body and rotton chassis, it's usually the other way round.
I fancy the idea of the front half of a Disco and a 130 HiCap pickup body to make a more comfortable double cab pickup that looks better than the Japenese stuff.
- DaveRoverMan
DaveRoverMan wrote:I fancy the idea of the front half of a Disco and a 130 HiCap pickup body to make a more comfortable double cab pickup that looks better than the Japenese stuff.
"Longranger 4x4" conversion or back end of a Mazda pickup cab grafted on
(some of the "flat plate & filler" jobs to close the cab off spoil the Disco's lines imho - though I probably need to finish one of my Landy projects to qualify for an opinion
- brickie501
I'm sure you could adapt a Disco' to make something different. If you're after a long wheel base Discovery though why only use four wheels?
Apparently I know nothing, a good trawl of the net turned up this...
This was built by Carmichaels as a '6x4 Custom Car' for a company called R.B.K. Ltd. Order dated January 1979.
- ACE
http://www.1000sel.com/index.php?option=com_content&view=article&id=52&Itemid=63
- ACE
