granada cosworth mgb ?
any thoughts,
patrick1 - Posts: 20
Whatever you do keep hold of the rear diff assembly and look for Hoyle Engineering. They do a bolt on subframe for the MGB that converts the car to independent rear suspension using Ford bits. Originally designed for a Mustang V8 conversion they do a Ford mounting front cross member as well. While you have a bare shell you could either get hold of a Hoyle set up or make your own based roughly on the Scorpio subframe and a few brackets.
You may need Sebring arches due to the Granada being a little bit wider but that not a bad thing.
Relentless Rob - Posts: 5160
mjslonergan wrote:Yep, thanks Rob, now I am going to be involved in the making of a subframe from whatever he can get his hands on for free... probably an old lawnmower a road sign and a zinc bucket...
You didn't say it was a £999 Challenge project.
Wowzers I don't remember the price list being so "if I win the lotto" territory.
The guys at Wisbech Engineering can do the same job for less but there's a two year waiting list.
http://www.facebook.com/pages/Wisbech-E ... 8806684220
It could be worth taking the original subframe off, rip it apart and modify it to fit a basic cradle mounted to the MGB's floor instead.
Rover V8 144 kg (318 lb)
Granada Cosworth ? Nowhere on the net (I can find) lists it's weight! It's a boat anchor, weighing roughly the same as a small moon. If a meteorite with the same mass impacted earth, it would wipe out all life (putting an end to Big Brother).
And it's been done...
http://www.kewengineering.co.uk/upgrades4mgs/Engines/mgb_cosworth.html
- ACE
"Ford Cologne 2.0-2.8 V6 380[lb]" or 172 kg.
(that's for the 12 valve version, not the cosworth)
http://fixrambler.com/engineweightchart.txt
- ACE
ACE wrote:And it's been done...
Looks like there's enough room for a supercharger in there.
Not being a bad influence at all.
Users browsing this forum: DaveRoverMan, Relentless Rob and 3 guests
