eBay Busses. You wait ages for one....
I've always like the Lancia Y10 (posh Panda). Always top of my £999 search list. I haven't seen one in ages and with the payday fiaries two weeks away two turn up at once.
http://www.ebay.co.uk/itm/1990-LANCIA-Y ... 1c2087e84a
http://www.ebay.co.uk/itm/Lancia-Y10-Fi ... 2568f36586
Typical.
Relentless Rob - Posts: 5170
Rummaged through a pile of doggies doos, @ West Sleekburn breakers, and liberated a Y10 A.R.B.
Straight on, with a couple of ally 'split' clamps I rustled up, problem solved.
FIAT Forum were all over the idea.... bunch of ***********!!.
well, it was a long time ago
tooSavvy - Posts: 536
http://www.ebay.co.uk/itm/1986-VAUXHALL ... 2315e6431e
Dad was given one of these as a company car, he soon fitted an SRi130 engine on Webbers instead of the "Bosch crap".
http://www.ebay.co.uk/itm/270850905894? ... 1423.l2649
I always thought the Maestro Van was a bit of an underdog. Not as desirable as the Escort Van, nowhere near as quick as the Astramax (when was the last time you saw one of them?). The humble Maestro Van never got the XRV treatment. I think an MG Maestro could donate parts or even the ubiquitous T series conversion, that's okay if you can't find your way out of the box. How about a MGtF rear subframe and running gear with an MGF box and a supercharhed KV6 making a Maestro 6R2 (?). Best of all there would be no need to tart it up so as well as a potential £999 challenger the build could be an awesome stealth weapon.
Punto GT powered Seicento...
http://www.ebay.co.uk/itm/251007588911? ... 500wt_1361
XE powered Cinquecento...
http://www.ebay.co.uk/itm/330694129062? ... 500wt_1361
MFrV1 wrote:Damn, that Sei turbo's been on Ebay alot!
Three times that I know of. It gets to within an hour of ending and the seller pulls it because it's "no longer available" (it wasn't high enough and the seller was too tight to spend an extra 12p to set a reserve).
I'd buy it for parts for my Panda.
http://www.ebay.co.uk/itm/Jenson-Healy- ... 008wt_1392
http://www.ebay.co.uk/itm/1974-Jenson-H ... 744wt_1392
http://www.ebay.co.uk/itm/1975-Jenson-H ... 029wt_1392
Damn it!
Ex-Nannini 75
http://www.carandclassic.co.uk/car/C188796
The 1750's big sister
http://www.carandclassic.co.uk/car/C299782
Check out the dash on this!!
http://www.carandclassic.co.uk/car/C288066
And finally the car I have always said I will buy after my dads caught fire on my 16th birthday (an electrical fault would you believe?), but only in 2 litre trim.
http://www.carandclassic.co.uk/car/C263622
I'm off to buy a lotto ticket unless anyone wants a kidney?
http://www.ebay.co.uk/itm/LANCIA-DEDRA- ... 500wt_1390
Bargain prices to.
Buy both for £795 and put the engine out of in the the back of the other and win the £999 with a twin engined four wheel drive Dedra.
What could go wrong?
Return to Ebay Links: Good, bad or ugly?
