Is it just me or are car stereos dropping the CD?
I started looking on the usual cheap search place Ebay.
You know how the cheap stuff from the orient is
usually ahead of what we get over here be it tv's, phones
or other media stuff!
As laptops dropped the cd rom drive and renamed them net
books. And the new TV mam bought has a usb outlet on the
side for recording programs.
So is it just me or are the car stereos following suit?
I found that the new cheap car stereos don't have the cd
option and only usb with memory card.
Example
from
http://www.ebay.co.uk/itm/180865282443?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
mitsuru - Posts: 1178
I expect it'll be like a lot of other stuff, if you actually WANT a CD player then you'll end up paying quite a bit for one.
There are car radios made to use an ipod but I'd like a DAB for the car that works the ipod well but not found one yet, dont want to pay extra for the CD that I wont use
*other MP3 players are available
As far as I can see CD's will be available for a long time yet and most new, well the stuff NME listen to, is still available on LP and besides what else are you going to put in the glove compartment?
@Hillbilly.
They are out there Clarion, Blaupunkt and Alpine do them iirc.
But then on most music there isn't that much to hear and as HBR says there aren't many cars that have a good enough audio setup to appreciate it.
I looked at getting an MP3 headunit for the jag but its a stupid non-standard size hole. Its a faff putting a new CD in, the old school changer is in the boot. It would save a few kgs as the changer isn't a light thing and the head unit could be half the size too. Sound system is pretty good but nowhere near as the standard fit on my old Primera which for a nominally cheap car was awesome in standard form.
I've never bought/downloaded an MP3 yet either, I buy em all on CD the upload them myself, I hope the CD is around for a long while yet too!
Even if you do have a top notch sound system in your car, it's got to be a fairly refined motor to make the best of it what with engine & tyre noise etc in the background
Reading information from a spinning disc when a solid state alternative is available is very backward.
Smiler - Posts: 1334
hillbillyracer wrote: I dont think more complex music suffers more than simple stuff when being compressed, it just takes up more memory in the storage device.
It does, simple music like the usual chart dross is very refined with often simple tunes and a quite limited selection of sounds so compresses easier. The difference isn't that obvious until you hear it on a really good system where the tiny details of the music aren't drowned out in background noise and poor system response. Which is very rare / impossible in a car (car background noise is usually >>70dbA). Best non-professional sound system I've heard was a 1970s Quad system which is amazing but with each speaker being ~3ftx4ft and even the manufacturer recommending a minimum room size (bigger than most people's house's biggest room) its not really suitable for cars. But as you say there is plenty of space on the SSDs so there isn't really any need to use a lossy compression so it will be as good as CD.
I think CDs will hang around for a long time. They have many advantages that SSD don't have (degradation over time being the main one) and until someone comes out with something else you can take home from the music shop they'll still be around.
A tape and six CD's would be £30 to £60 to replace and take about ten minutes on eBay. Even at 10p each from any legitimate music download site 3,000 tracks would be £300 or if you store them all on your laptop and transfer the files to the new head unit it's a good few hours watching the animated egg timer.
If I were driving a CIT van then I'd consider it but knowing several hours and possibly hundreds of Pounds of money and time I could do better things with are a broken window away; I wouldn't bother and get a memory card or stick reading one instead.
Relentless Rob - Posts: 5151
Each to their own but for me it works fine, I've never had a sound system good enough to hear the difference & mabye for my ears wouldn't be worth the outlay anyway!!
If I leave the car anywhere I slip it in that little pocket in the front of my jeans. (yes, I finaly found a use for it!)
I have music on my phone - usb lead would do the output work but I don't have anything to plug it into except the tape player...
