Fuel pressure dropping?
Start the car and fuel pressure sits perfect at 37psi and will remain the same for ever if I left the car ticking over. Drive the car and over a mile or so the pressure drops to a point the car is undriveable, to around 15psi. it'll continue to tick over at 15psi, but the pressure won't rise again until the car is stopped, fully cooled down and then the same scenario happens again?
I've replaced the following;
Fuel pump (twice - brand new Bosch pump fitted now), pressure regulator, filter, supply fuel line.
I've also checked the tank breather - all fine (no vacuum)
The only part of the fuel system I've not replaced is the return line, but dont see how this could be linked.
Anyone came across a similar problem?
Cheers
- gmcmotorsport
I don't know what your fuel line is made of but the neon
came off the production line with mild steel pipes.
I replaced mine as well as the brake lines when I found
that they were rotten.
And some of the clip connections were leaking by spring
apart a bit under high pressure but not enough to come
totally apart, and would pull themselves back together
when no pressure.
(On later Neon models they change the pipe metal and the
connections)
mitsuru - Posts: 1178
Fuel pipe is high pressure plastic - 10mm feed, 8mm return.
I'm stumped!
- gmcmotorsport
TeamTotalWankel - Posts: 2355
Good point Owelly, will clamp return & check regulator (although it is a new adjustable regulator)
- gmcmotorsport
Relentless Rob - Posts: 5151
Planning spending a few hours on it tomorrow evening, will post update afterwards
- gmcmotorsport
- andrewg1323
The one thing that i haven't checked since fitting them is the injectors. They are new (remanufactured).......unlikely, but I'm wondering if these, or one of these, is causing a drop in pressure. I really don't think so as the engine is definitely suffering from fuel starvation, not flooding but to be honest everything else has been replaced (literally)!
Anyone had any problem with re-manufactured injectors?
- gmcmotorsport
