Radiator Sizing
I think the best way would be to try it don't let it boil over and get Alu-tec or someone to make one the same size with double the core.
Relentless Rob - Posts: 5186
Tojiero wrote:The Chevy's in a Cobra. Just trying to source an "off the shelf" rad. for the job.
Does the Scooby rad fit nicely in the available space then? If so then give it a go. Worst case scenario, you'll need to get an uprated version of the same rad.
- Tojiero
Users browsing this forum: Rippthrough and 5 guests
