It is currently Thu May 23, 2013 11:53 am
1989 Skoda Rapid 136 The "K-Rapid"
Postby Kieranzxt » Fri May 18, 2012 11:20 pm
Hello, I'm Kieran and this is my 1989 Rapid 136 I've owned for a about 3 years.
Started out stock and had been abandoned in a council lock up, after killing its head gasket. I dragged it out and built a fast road engine for it - gas flowed head, Kent SK3 cam, various carbs, 4 branch exhaust from the czech republic.
But I got fed up of killing pistons....
So I decided to fit a 1.6 Rover K Series engine.
I adapted the Skoda flywheel onto the Rover crank, made an adapter ring and a spacer behind the flywheel to hold a spigot bearing and then got it all balanced up.
Car runs fantastic, and 4000 miles later its a great car. Smooth tractable with an amazing 16v howl at the top end!
Ignition is done by megajolt and the engine runs 33mm bike carbs. the result was this:-
Kieranzxt
Postby mjslonergan » Sat May 19, 2012 9:19 am
Nice looking car, and a very tidy conversion.
Postby Relentless Rob » Sat May 19, 2012 10:45 am
Very nice. I always preferred the Rapid to the Estelle. They were shipped into the UK at King's Lynn and would pass me on transporters every morning as I walked to school.
Is that beige one in the first photo the one that's running the VAG 20V Turbo?
Postby Kieranzxt » Sat May 19, 2012 12:34 pm
No, The beige one belongs to a Scottish lad called mark, and is running a 136 Skoda engine. He loves polishing it!
Kieranzxt
Postby tooSavvy » Sat May 19, 2012 7:43 pm
:wave: Hi!
I had an 'E' reg Black Rapid. 'Fudge' velour interior... :think:
I had the engine swapped for the 136 8Port, non Ric..... and when the Back [only!] Box blew, I had a local exhaust place weld up a 'y' to the twin downs & loop a length under the splashshield and fit a Mk111 Cortina rear box on.... Sounded err.... DIFFERENT! :lol:
I fitted a dash switch 'override-ON' to the fan circuit..... in a queue of summer traffic, the engine got really hot before the 'sensor' [in the rad] looped in the fan...... good mod!!
They seem to all leak down the rear window rubber seal :shock: ... dribbles down and rots out the rear wheelarches/sill
Std SKODA alloys, but 185 on the back and 175 on the front... never had a problem with that.
I fitted Lumenition (GR8!!!) but had a weird problem.... the top of the dizzy shaft is 'peened' in place, where the bob weights locate - this came loose and stopped the car.
Recovered back and I stripped a scrappy 105 dizzy of this shaft [with added CentrePunch work..lol] Sorted :wink:
My alloy spare always resided in the boot..... seen alloys that looked like white Weetabix!!
Starter Motor.... don't get me STARTED.... had two from the dealer, as warranty, finally got a scrapper and had it rebuilt by a local rewind guy... HE did it the way the Factory should have. Sorted :wink:
The original motor would pop me along at 80 [with a tail wind] indicated.... replacement swap 136 was good for 95 [indicated]..... a fair investment :mrgreen:
Moved it on to a 2nd hand lot dealer... who was keen to give me a good price... as I got a job with a free van (just us two, see).
FAB.... I loved it [I'm an ExHillmanIMP nutter...see]
Users browsing this forum: cinqabarth and 11 guests
