Jaguar Land Rover
The Rover V8 isn't bad at what it does, but performance figures are crap without spending lots of money, and on paper the 3.6 will just about equal the 4.6 Rover, and the 4 litre betters it with no tuning (225bhp/380nm torque for the 4.6 Rover and 221bhp/325nm and 245bhp/392nm for the 3.6 and 4 litre Jags) which left me thinking wondering on how it might fare in a Land Rover application.
I've seen the V12 put in a classic Range Rover, and some Germans put a 4.2 XK lump into a Series II LWB version, so the concept is workable.
Better still the auto box is a ZF4HP22/24 which was also used with the V8 in the Range Rover and Discovery, so bolting it all together and having 4WD will be nice and easy.
The one thing I can't find much useful info on is the length of the engine, or what's required to make the fuel injection work.
One assumes as the Lucas 5CU setup evolved from the same system as the 14CUX it would be similarly easy to make it work?
Whilst knowing the length of the engine will allow me to work out if I could fit it under the bonnet of a Defender without any fuss, or if I'm gonna have to shunt the gear box back to keep it all behind the radiator.
Anyone have any thoughts/knowledge to share?
- DaveRoverMan
I'm also convinced I've read a magazine article about an AJ6 transplanted into a Range Rover Classic - just don't have my stack of 'Land Rover porn' to hand!
Niether of these revalations exactly prove it will go in but, generally speaking, what's good for the old Range Rover is good for a Defender when it comes to engine swaps...
- brickie501
Landrover fitted a six cylinder to some LWB Series II and III's (With modifications to the bulk head and other stuff).
Pretty sure I remember reading (Land Rover Owner?) about a series landrover converted to run a 4.2 jag straight six, some years back.
- ACE
I've played with more than a few Series II six cylinders in my time, the Rover one is a fairly short block in comparason to the Jag though?
The last magazine article I saw about an XK engine in a Series II was Land Rover World last year sometime, a bit of fiddling to make it fit, but all ended up looking as if it had just rolled off the line.
A little bit of inspiration...
- DaveRoverMan
